iRacing / Sim Racing solution
19 Oct 2010
Hi
Thoughts on the following for an upgrade to my system.
I've a Lan Cool Mesh case, a 3090FE and a 1k corsair PSU. Gaming at 1440p triple screen.
Thank you.
My basket at OcUK:
Total: £1,325.41 (includes delivery: £10.50)​
You will need to update the bios on a Z690 motherboard for the 13th gen to work so unless it has bios flash button a Z790 will work straight out the box.
13700k would be a cheaper better alternate for gaming.
Thanks. I've access to 12th gen's for any BIOS update. 13700k is a better gaming CPU, that's interesting. Thanks. I'll look into that.
It's a better cost alternative price to performance, the 13900k has 8 more e cores and clocked higher but there close in gaming for a £200 price diffrence
Mite invest in a slighty better motherboard .
IRacing’s long standing problem is ”minimum frames”, it’s quite easy to get 200fps with a far worse computer than yours (excluding ai races) but you will still get big dips on certain parts of certain tracks, even with a 4090. The game is all about CPU, single threaded performance is key.
