Irritating firefox browsing problem
8 Jan 2003
Sheffield, UK
For ages now, I've been coming to overlcockers, and when I browse through the catalogue, and go back a page, I wont be able to access any other part of the catalogue except the part I just visited.
For example..
Goto the main site, click "Products", then "Components", now press the back button and try to access "Peripherals". For me nothing happens, and the only way to continue is to refresh the page, or open the link in a new tab. Is this problem just unique to my firefox setup, or is it the same with everyones?
For example..
Works fine for me. What have you manually set?
Yeah, fine here.
Does it happen with another browser?
Changed any settings, what extensions are you using, tried it in safe mode (ie with extensions disabled), with a new profile?
What ISP are you using?
OK, I didnt really think it would be the extensions, but I tried disabling one extension i like to use which offerrs more options on tab browsing. "Tabbrowser extensions". Anyway the problem went away once I disabled that. So I guess I gotta find out what in the extension is specifically causing the problem if thats possible.
Thnx for your help guys.
I'm using an extension called Tabbrowser Preferences and I don't get the problem you're getting. Is this the same extension you're using?
