- 18 May 2010
Hi
Just wondering if a high quality 650W PSU is enough to power the following?
I was going to get a 750W but I could do with saving the difference in cost plus the 750 isnt in stock anywhere and has no lead time available
There will be no OC
Phenom 965
4GB RAM
5870 x 1 (I will only be running one GPU)
3 x SATA HDD
2 x SATA Optical drives
I've done PSU tests and the result is 560W but the way I see it is a 750W PSU will be under less strain and theres only £15 difference really so it might be worth waiting for the 750, I have to wait to for the mobo to be released anyway so I dont mind waiting up until that point
Any advice appreciated, thanks
There will be no OC
Phenom 965
4GB RAM
3 x SATA HDD
