can you get a free eyetest if you already have eyesight problems but you've not had a test for say 3 years? as i'm allways up for getting more mony out the companyMNuTz said:Ive used a monitor for well over 10 years, for at least 5 hours a day and my eye sight is perfect.
Chances are your eye sight is faultering and using the monitor makes your head hurt. My g/f had exactly the same problem, turned out she was far sighted, it just started developing with age!
You should get a free eye test from your employer if you use a VDU as part of your job!
Solouko said:can you get a free eyetest if you already have eyesight problems but you've not had a test for say 3 years? as i'm allways up for getting more mony out the company
Yeah I have a bit of a problem with dry eyes. My eyesite is also very bad (short-sighted) and is continuing to get worse. I'm sure it must be partly down to too much time spent in front of a screen.Mohinder said:I'm of the opinion (and so's my optician) that for many people, spending such a lot of your time focussing on something so close to you can gradually make you somewhat short sighted. I dunno if that's why I'm short sighted, but I dunno.. it sort of makes sense.
The worst thing is the dryness though as Kreeeee mentioned. Especially if you're working - concentrating on a monitor, you don't blink enough. Apparently if you do design/data entry/any work that means you concentrate on a monitor a lot it can cause a couple of problems for contact lens wearers, because your eyes dry out easier. I have quite dry eyes anyway, apparently, and I smoke, which makes them drier still, so when I finally get round to trying contact lenses, I need to see if my eyes can get used to them because they're so dry
greenlizard0 said:It depends what type of porn you're looking at. *boo boom tish!!*
But nowadays newer moniters with faster refresh rates tend not to be a problem. The problem with officers and lots of machines isn't the screens in there making all their users eyes hurt, it's the many computers blowing cold dry air out which dries the local atmosphere.
