Is anyone else having a major mozzie problem at the mo? its doing my head in
But not enough to cause problems.
Well that's a pretty stupid thing to say isn't it? The OP clearly has a problem, I have problems with Mozzies, we both live in the UK.
Just cause they don't cause Malaria or bother you doesn't mean they don't cause problems.
:mad:
Sorry pal it isn't.
I don't have problems with them here but I do on the continent. so bad luck. For the great majority they aren't a problem in this country unless you live next to swamp.
hold on here, a nympho certainly wouldnt be used for clearing the mozzies/midgies (what ever) lets get this straight (no pun intended)
Try aromatherapy oils like citronella, anything citrus basically they won't like. Neem and tea tree should also put them right off you. B vits, there's another one in your favour.
Go to Boots and buy a jungle formula mosquito killer plug-in. It uses a two pin plug so you will need an adapter. It will kill them all, its very effective.
