Is COD2 limited to 91fps?
14 Jul 2005
Surrey
Hi all,
Every time i run COD2 i get a constant framerate of 91fps, never higher and never lower. Is it limited to 91fps? If so then is there a modification that can be made to give higher framerates?
Thanks and sorry if it sounds like a stupid question :D
V-sync disabled in both drivers and game. Running in DX7 mode.
Do you mean 90Hz monitor refresh rate? Monitor's set at 72Hz.
Thanks for the replies :)
in the console (¬ tilde or whatever it is :P)
/cg_maxFPS 0
fps must be caps.
0 means unlimited, so whatever it can output, 91 seems pretty healthy though :P
It's probably at cg_maxFPS 91 or something.
I think it's cg.. might be com or something, have a look, it pops up wiht predictive.
/cg_maxFPS 0
fps must be caps.
Didn't know that, i'll check it out when i get it installed ;)
lol i totally posted the wrong one - 125 is the sweet spot for cod by the way - 333 being the next level - id leave it capped so it dont rapidly chaneg a lot
