Is copy and paste for large files exact?
25 Jul 2004
I've tried looking online for an answer but couldn't find anything. Basically, when copying a load of mkv files from one drive to another, is the copied file an exact copy? Lets say I copy/paste a 50GB file, is there any chance of the copy not being the same as the original?
Cheers
It's not impossible that the copy could mess up somehow, but generally a copy paste is exact yeah.
If you want to be certain that files are identical you can generate a hash.
The chances are very low as Windows does Cyclic redundancy checking (CRC) when copying files, the exact internals, in fact how CRC works, are beyond me.
From experience I've had files that have failed to copy partway through with a CRC error so I'm guessing Windows compares the CRC values on chunks of the file, could be 512k as that's the default NTFS block size.
Bit of a strange question. Are you just concerned about data corruption when copying large amounts of data? As mentioned above I'd just generate a hash of each file and then do a check after the copy to confirm all is intact.
If the hashes match, then the copy is a perfect match.
Yes, it's mainly data corruption I'm worried about. I'm currently copying about 30TB of mkv files to LTO8 (just using LTFS, not Veeam or anything like that). It would be a disaster to recover a file and discover it's corrupt.
