is cpu socket frame removable?
14 Nov 2005
Belfast
k just bought upgrade, including an ASRock 939A8X-M and a zalman 7000b cu. basically the mobo has a big frame round the cpu socket which i think can b taken off (will try to get a photo up). has any1 else had this problem? all i want to kno is wots the best way to take it off
thnx in advance
You mean the CPU retention bracket? Yes, it is removeable. Mine was 2 push pin type thingys:p and the back plate is stuck on with some sort of strong sticky pad, that levers off too.
