You'll need to buy earplugs or speak in hushed tonesNot what I want to hear![]()
Did you get it running?
EDIT: Just browsed the MM...
Great - pleased with the results?Yes did get it going eventually bud, forgot to update you on it.. just needs OS now and were good to go..![]()
nobody will have it that says a lot
Hahah think I'll buy the EVGA psu on payday not liking what I've read about kolink....
I bought one thinking "Hey they're owned by the same company as OCUK, can't be bad", it blew up two hard drives because apparently testing things before they leave the factory is one of the steps they skip to get the price down XD
It's the normal cold-boot start up process.There's something I've noticed lately with this build I've done...
1. Press power button
2. LED Fans spin for a second or two
3. They then stop and LED's go out
4. Then it starts again and powers on
Any suggestions as to what it could be guys
You'll notice it doesn't do it with a restart.
No worries.Thats good to hear then.. thought something was going wrong.... phew
Thanks bud
No worries.
How's it running otherwise?
You can use a cable tie at the end of the GFX card and support it on a bay drive hole (or similar) at the top of the case. This can eliminate sag and protect the socket if required.Running brilliant thank you... my old man bought his 970 down and we installed it yesterday, However, looking at it now it looks to me as though it's lower on the right side as if it's to heavy for the motherboard slot. It might just be my eyes though
