I use mine on the motherboard rather than through the controller as it was b0rked when I bought it (from new) it ran at a max of 900 RPM, and set my Fan warning buzzer off constantly.
Only problem is the reason the fan is noisey is because it shifts a lot of air for its size. quieter ones wouldnt shift as much so wouldnt cool as wellbrightside_ said:simple option if it's too noisy, buy a new fan?
True but if you buy a quieter fan you can then turn it up when going on a game etc and have it running at low rpm when watching a DVD or listening to music or when idle at night etc. I use a noise blocker S3 on mine and the lowest rpm is 1600rpm which is a lot quieter than the ambers 2000rpm, then it can be turned up to 3000rpm if it needs to be. I have never had to turn it up and leave it on low even on games, i have overclocked my 3200+ to 2.2 as well. There are definitely better coolers out there though, i think ill go for a zalman next time.sgoaty said:Only problem is the reason the fan is noisey is because it shifts a lot of air for its size. quieter ones wouldnt shift as much so wouldnt cool as well
keep your EVO 33 just put 2x 80mm regular fans on it in a push pull config and it will work fine, thats what i have done with my coolermaster hyper 6+ and it works fine even at low speeds with an OCed CPU whilst playing a game, CPU never goes over 45C but thats an AMDmarv_1 said:Im going to get the ThermalRight SI-120, just waiting for a new thermaltake 12cm fan to be released in the uk
. If i was you id get freezer 64 a lot of people have recommended it so it must be good, the ThermalRight SI-120 plus a decent fan is going to be expensive.
