I think it probably comes down to how beefy your computer is. I've been living with the AW3425DW for about a week now and the only time I see it flicker is during loading. Once a game loads and I'm playing I have yet to see it flicker. I think that's down to how fast my machine is as well as the games I'm playing. I don't play anything that my machine doesn't get really good performance on. It is a few years old now, but is still pretty beefy. I have a 12900KS and a 3080 Ti, and nothing I play suffers from bad performance. So I suppose the fact that I'm never near that LFC zone is probably why I have never seen any flickers, bar when things are loading up. It does flicker a fair amount during loading, but the AW3423DW it replaced didn't seem to do so very much. The AW3423DW did flicker during loading occasionally, but it was kind of rare in comparison. And never did during gameplay. This new one flickers quite a bit during loading, but once things are loaded and the game actually starts running it is fine for me. So if that's the key, simply avoiding the low end of the possible adjustment range, then I don't think it really is much of an issue. As if that's the case, it just means you need a PC upgrade if you're getting flickering. The AW3423DW had a 144 Hz refresh limit (at least in HDR it did, due to bandwidth constraints on the wire, 175 Hz for SDR) and pretty much any game I play was more or less stuck riding at the upper limit. So if the problem is riding around at the lower limit then getting hardware that's faster should solve it.
This AW3425Dw now gives me a 240 Hz upper limit, and not everything I play sits at that much higher limit, but of course I'm not getting slower performance that before, so I'm sitll nowhere near the lower limit. The machine now spends a good deal of time well above the 144 Hz I was previously limited to, and sometimes sits at that 240 Hz new upper limit, but it does spend a lot of time fluctating between those two marks. As I say, it isn't flickering on me, so I think everything's good to go here. I did finally end up sending the old monitor back to Dell and kept this new one. I'm pretty happy with it after testing it out for nearly a week before boxing the old one up and sending it off.
