Man of Honour
- 13 Nov 2009
- Northampton
Not sure but you can buy the rebuild kits for the ratchets for a fiver so not exactly expensive to repair.
Working on new cars then? I've rounded plenty with those sockets. Can't see any possible benefit to a 12pt over a 6.
I was once told that they don't replace 'moving parts', when I needed a new ratchet (it jammed), but the old lady behind the counter said she'd do it anyway as the boss wasn't in
I don't really get why the moving parts in the ratchet aren't covered but everything else is.
Why not?
I over torqued it apparently. Which is true, and pretty much the only way you could break one aside from crushing it in a press, but there you go.
which is a shame since I've got a lot of breaker bars in 3/4".
I've had a look at Machine Mart and they don't seem to do a 1/2" to 3/4" adapter eitherThey must be out there somewhere by a reputable brand!
I've got an older version of the set than this, mine goes up to 32MM 1/2" drive, but what really gets me and caused me to abort a brake bleed the other day because I thought the car was at fault: The 'DEEP' 3/8" inch drive sockets although 50+mm long only have the socket cut into them for the first few MM? So a 'DEEP' socket with only as much bite as a shallow socket? Talk about cheaping out...
An older Halfords set I've used has the deep sockets with them being machined properly all the way up the inside as they should be.
The shallow cut on the socket wouldn't go over the brake nipple I needed to undo. I assumed it was the wrong size though and din't look down into the socket at the time.
Otherwise, not to bad a set!
Why would you be using a socket to brake bleed. How are you going to let the fluid out with a socket stuffed on the end of the nipple. Spanner all the way![]()
