Is it possible to have both Windows 7 64 bit and Windows 10 64 bit operating systems on the same SSD or HDD? If so, how does the computer know which one I want to use at any time?
Allows me to have separate drives using the same hardware. When one has an issue or needs reinstalling, the other is totally separate. Would be ideal when you give up on Win 7 as no need to mess about with partitions. Just remove win 7 drive.
Not good for laptops though Sometimes the only choice is to partition and duel boot. I now have Windows 10 on my Macbook Air 2011 model as well as MacOS.
