Is it possible to turn off the fan slider in MSI AB
Man of Honour
21 May 2012
Dalek flagship
As in the title is it possible to turn off the fan slider in MSI afterburner as it is a bit pointless if you use watercooling.
Thanks.:)
I just leave it at the minimum percentage and then turn off auto.
I suppose a modded bios might allow it to be set at 0%.
Why does it matter? It makes no difference what you set it to? :confused:
It is not the end of the world having it there but with all the stuff in AB you can turn off on the monitoring side I was just wondering if you could turn off the fan setting option.:)
