Is it safe to lay a gaming rig on its side???
3 Jun 2013
Hi
I'll soon be getting a new gaming rig with the CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
It's going to be used in the living room and I've been wondering is it safe/ok to lay a pc on its side these days?
It would look a lot better in my set up laying horizontally but if it's not safe I'll find another solution.
Sides of case is tempered glass and not blocking vents etc
edit - picked a nicer case
As long as the fans aren't blocked there's no reason to expect any problems. Convection makes very little difference so the airflow will basically be unchanged.
There's no way I'd want that case anywhere near my living room, but that's your choice.
I'd get some little rubber feet to keep the glass off the shelf but otherwise I can't see why not (as long as it's orientated with the motherboard on the bottom, of course).
lol I know what you mean about case design...so ive changed it to the
Reviews are good and looks a lot better if on display as horizontally seems fine
Yeah I might get 4 nice rubber door stop things to give it a little more height on its side.
Less awful I suppose.
Aren't there any decent horizontally oriented cases out there? You used to be able to buy some quite nice cases that looked more-or-less like Hi-Fi components and wouldn't look out of place in a living room.
Im getting it pre built so limited to what is available.
Quite happy with the new case so that will do and can always hide away if I need to
Cheers but ordered the build and can't change case again and the one linked isn't available there anyway.
Happy with build now and will try it horizontal and see how i get on.
Cheers all
you wont have issues unless you blocking vents, but there are cases design for such things, so better of looking for one of those.
