xp = Pants
Why?
It's still a good OS, just not as good as 7 (or even Vista IMO - but then I had no issue with it on release, whereas some did).
3.11 was a good OS for the time, but things move on. 9 Years is a long time.
It's not "pants" though is it?
It's only still used in business because of the cost to upgrade. The only way I am getting Windows 7 into client's businesses is buying new machines!![]()
Hi,
Thanks for the repliesThe reason I want to go back to XP is that one or two programs don't work under Windows 7, example picture it. I use that program a lot to make cards and bussiness cards.
I have tried "compatibility" mode but it still does not work under that either.
Also my printer and scanner don't work under 7 either.
XP is still a good OS. Also my next door neighbour does not want to upgrade to Windows 7 either.
I still have a corner in my office with a laptop running win98se, the reason? To run DOS programs. They also demand an epson compatible printer on the parallel port so I have one of those also. VM doesn't cut it with these.
Ideally they should be rewritten, but as they do the job required, no one has taken the effort.
andy.
Hi,
