My local independent reckons Kwikfit (or at least some Kwikfits) don't put UV dye in the mix
They don't because they can't / won't diagnose problems, they plug the machine in and regas only, if it leaks it's up to you to get a proper place to use UV dye and diagnose your problem
My local independent reckons Kwikfit (or at least some Kwikfits) don't put UV dye in the mix - he has regassed customers' AC a proper mix (incl. UV dye) after Kwikfit jobs leaked without showing why. The machine should say if the AC can hold a vacuum, but a slow leak may beat the proof load...but you should be able to get your money back from Kwikfit the AC doesn't work again after a week or so.
Apparently Kwikfit are getting less stringent on what constitutes successful regassing now. 10% reduction is supposed to be a success. So what? 15'C down to 13.5'C?! Definitely check beforehand.
They shouldn't be touching your working parts, the regas is a valve by the slam panel, it's either a coincidence or they tried to get it working and messed it up.
10% reduction in temperature hey, from 15C to -14C is pretty good I reckon![]()
No, don't, have used them twice failed twice.
It is now illegal to diagnose leaks with dye I believe. It is supposed to be done with nitrogen apparently.
Not illegal to diagnose leaks with dye I think. I believe it is illegal to add refrigerant to a known leaky system.
Hence you can use nitrogen / dye but not R138 / dye if you know it's leaking somewhere.
Will be fine, is a fully automated machine to do it, idiot proof.
