Hi,
Question: Is 2 better than 1?
Would it be better to get multiple HDD, so for example, 1 is for the OS and the other is for media (movies and music) ...rather than just bang it all on 1 HDD?
I really want that new Samsung F1 320 (HD32HJ) x2 ...but its delayed big time and I'm looking to build in a months time, so I may be forced to get something else, such as the bigger F1 640 (HD642JJ)
But then it would only be 1 HDD. I think I'd want atleast 2 HDD with a maximum total of around 640gb
I would like to stick to Samsung, as they are cheap and most important of all, quiet. You may want to suggest the WD, but my bro got a 250gb last year and its loud. So that kind of put me off, big time.
My spec thread
I did search before posting, but I want a solid answer.
Thanks
BON
My spec thread
Thanks
BON
