Is my 64GB Stick kaput?
25 Jun 2005
I've got a Kingston 64GB USB stick
I connected it to my windows machine today and noticed it was only 115mb capacity.
I used the cmd prompt to clean/partition and format - all good, or so I thought. Later in the day I tried to move some files to the stick and windows told me it needed formatting first - Windows would not allow me to format. Kept reporting errors.
In Disk Management I could see the hard drive - all the other drives were blue showing used/available space, this stick was black and unallocated. Create new volume reported an error.
CMD is reporting errors if I 'select disk' and my iMac and MBP do nothing when I connect the stick to them.
Nothing mounted on desktop, finder, nothing in disk utility or system information.
Bin job or am I missing something?
Cheers :)
Is it just trying to format the drive and failing?
Are you formatting it in FAT32 or NTFS?
The last time I had an issue trying to format a USB drive in FAT32 with it constantly failing, I changed it so I formatted it in NTFS and it worked (it also allowed me to complete a FAT32 format of the drive).
If nothing can get the drive formatted, then it is hosed and only fit for the bin.
