Is my Agility 3 Causing Problems?
31 Mar 2010
I've had my pc since around the 23rd of June when I ordered all the parts from OCUK and at a guess since then I have had to reinstall the OS around 7 times on my Agility 3. Everything works for a few months and then problems begin. Programs begin to become unstable and lock up more and more frequently, videos don't buffer correctly and eventually the OS has a fit where on startup it won't load any programs, windows explorer doesn't list any drives if I select computer (although they are still listed on the side) or windows begins to fail to load at all.
Honestly I don't really know what is causing this, but I have read about lots of problems about Agility 3s. Does this sound like hard drive problems to you guys and are they any tests I can perform?
Note: The drive is running the current 2.15 firmware.
Running on an Asrock z68 extreme 4 (not gen3). Bios version 1.6, latest is 1.7 which I will upgrade to in a bit. Seems I must wait several minutes after restarting for windows explorer to crash and restart now before I can do anything.
what dram and vtt voltages are you using? could be memory related but id update to latest bios first
