Is my hard drive dead?
4 Nov 2007
Scotland
So yesterday I moved my pc to my livingroom to watch a blu ray as I couldnt get it to stream properly (licence to blu ray software expired) and when I went to start up my pc it came up saying:
PC said:
Disk Read Error Occurred
Press CTRL + Alt + Del to restart
So I restarted and the message keeps coming up. The hard drive still shows up in the BIOS however iot only reads as 33MB. I then transferred it to another pc and it shows up in my computer and device manager, however it tells me I need to format it? What does this mean? Is there any way to save the data still on it and will it even work once reformatted?
It's a samsung F1 1TB. I've tried a new cable and it didn't make a difference. What sort of things am I looking for to indicate if the drive is bad in Crystaldiskinfo?
OK, it says health status: caution (yellow)
Reallocated Sectors Count [05]: 63
Current Pending Sector Count [C5]: 27
Uncorrectable Sector Count [C6]: 1
Check ID 05 and C4 through C8. However it might just show up as bad straight from the get go. Use Seatools for Windows and do a long generic test, even though Samsung hdds are now Seagate it dosen't matter anyway what brand it is.
a) run a chkdsk if it fixes the issue and leaves no bad sectors you had a virus
b) if it fixes the issue and leaves bad sectors replace the drive...
c) if (a) left no bad sectors run a chkdsk /r jsut to be safe if there are bad sectors replace the drive
Did you get this from your A+ class? :p
C8 is reported as heathy.
When I go to hard drive properties to schedule a chkdsk it tells me I need to format first.
attach to another working PC via sata cable - the OS should (hopefully) do a chkdsk on boot?
It is already connected to another PC as I can't get past the "Disk read error" message on my main PC. It didn't do a chkdsk unfortunately.
Looks like I may just have to format to get anywhere...
I had one exactly like this last week (i see a few) it took several reboots for the windows install to decide to do a chkdsk, then it took 24hours for the chkdsk to complete it gets stuck on bad sectors for ages....
I think trying to force a chkdsk is the best bet before trying recovery software... (oviously if it refuses to chkdsk you only have that option)
I'll try rebooting a few times and see if I can initiate a chkdsk.
EDIT: I booted in safe mode and attempted to run chkdsk from there but it reported "Cdkdsk cannot be run on RAW file format" or something like that. Guess that's because it;s being read as an unformatted drive. Furthermore, when running the format tool on windows it is still showing up as 30MB. Dammit :(
I managed to resolve this problem. I did some searching and found other posts on google of hard drives showing up as 32MB. They pointed to some sort of corrupt file address system and from that I found out about samsung EStools which has a built in function to restore the hard drive to it's default capacity. Skip forward an hour and here I am in windows just about to start an extended chkdsk on the drive. Score.
