I have a 2.5in 320gb WD Scorpio Black that I took out of my laptop to use on my pc and it doesn't seem to work.
When I tried to install windows on it when I first got my pc it said it could not install to it so I had to use another hdd. So I try to connect the hdd to my pc when everything was installed by sata to usb cable and windows made the noise that tells you something had been connected, but it didn't show up in My Computer, so I went to Disk Management and this is what I see.
So is it dead because I can't put new volumes or format when I right click it.
Thanks.
Thanks.
