I've done a quick google and people are saying theres not much difference but we all want our machines to run at the best they can. So I've tried to enable AHCI in the bios as I believe this will make it run in UDMA Mode 6 but it blue screens just as its about to boot into the desktop. Anyone got any suggestions??
I went to ACHI mode from an install of Vista where it previously was not enabled and all I did in Vista before went into the BIOS to enable it was to...
1. Exit all Windows-based programs.
2. Click Start, type regedit in the Start Search box, and then press ENTER.
3. If you receive the User Account Control dialog box, click Continue.
4. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
5. In the right pane, right-click Start in the Name column, and then click Modify.
6. In the Value data box, type 0, and then click OK.
7. On the File menu, click Exit to close Registry Editor.
Then reboot - previously I had the latest Intel drivers installed....
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=816
I had copied the above from a website ages ago in case that I needed them and, for me, it worked fine. Vista booted with no BSOD and found the drives and installed the drivers. If you follow it and you FUBAR your system don't blame me
However it made tidily squat difference to anything from a practical or benchmarking point of view. And considering it then took longer to boot up, only a few seconds I know, I decided to go back to the non-ACHI interface.
My drive(s) show this....
