Is my iPhone SE 2020 battery knackered?
3 Aug 2015
And how do I un-knacker it?
In the past week it’s started shutting down at a reported 37-39% battery. When I try to switch it back on I get the “need to plug in” / red battery symbols on screen.
I read online that I could ‘reset’ the battery by plugging the phone in for a minute then unplugging, running down to 0% and then charging to 100% but that doesn’t seem to work because it won’t run all the way down to 0%.
When it does shut down it is immediately on 11-14% battery when I plug it in.
Have tried a hard reset while it’s showing 14% and it went back up to 40%.
Battery screen in settings still shows 90% battery health. Any suggestions??
Balls. :D
Might just get a 14/14 Pro instead.
£49 for a new battery from Apple or £1000+ for a new phone... decisions, decisions ;)
/edit - Have you tried a calibration? I didn't think it was still a thing these days but @Raymond Lin had some luck doing it recently on a phone that was playing silly whatsits.
As in battery calibration or something else?
Battery calibration. Don’t ask me how it’s done, I’ve got no idea.
No idea if there is a "proper" method from Apple but i've found draining the iPhone until it powers off, leaving it overnight before doing a full charge with the phone still off, then use the the phone and repeat does appear to help "calibrate" the battery and usage.
It is a lot of aggro though considering the cost of battery replacements...
Letting it stay off after shutdown for a few hours then charging to 100% and leaving it charging longer than normal means the fault seems to have stopped. Will now drop below ~37% charge without shutting down. Saved me £600+, at least temporarily.
