Hi all.
Purchased 4GB memory from OC on Saturday.
It was the Geil 4GB (2x2GB) PC6400C5 800Mhz
which states
I installed the trial version of Everest which shows:
Does that mean my memory is running at 6-6-6-18 instead of 5-5-5-15 ?
If so, how do I change it please?
Everest Memory Timings:
Vista 64 premium, Gigabyte GA-P35-DS4 E6600 core 2
many thanks
Phil
which states
PC6400 800MHz CAS 5-5-5-15
Cant tell you what DIMM3 says as it wont show on the trial version.DIMM1: GeIL CL5-5-5DDR2800 5
Module Name: GeIL CL5-5-5DDR2800 5
Serial no: None
Manufacture Date: Week 27 / 2006
Module Size: 2048 MB (2 ranks, 8 banks)
Module Type: Unbuffered DIMM
Memory Type: DDR2 SDRAM
Memory Speed: DDR2-800 (400MHz)
Module Width: 64bit
Module Voltage SSTL 1.8
Error Detection Method: None
Refresh Rate: Reduced (7.8 us), Self-Refresh
Memory Timings
@ 400 MHz: 6-6-6-18 (CL-RCD-RP-RAS) / 24-51-3-6-4 (RC-RFC-RRD-WR-WTR)
@ 333 MHz: 5-5-5-15 (CL-RCD-RP-RAS) / 20-43-3-5-4 (RC-RFC-RRD-WR-WTR)
@ 266 MHz: 4-4-4-12 (CL-RCD-RP-RAS) / 16-34-2-4-3 (RC-RFC-RRD-WR-WTR)
CAS Latency (CL): 6T
RAS to CAS Delay (tRCD): 6T
RAS Precharge (tRP): 6T
RAS Active Time 9tRAS): 18T
Row Refresh Cycle time (tRFC): 52T
RAS to RAS Delay (tRRD): 3T
Write Recovery Time (tWR): 15T
Read to Write Delay (tRTW) 8T
Write to Read Delay (tWTR): 5T
Refresh Period (tREF): 3120T
many thanks
Phil
