I have normal Sky, had the same box for about 3 1/2 years, a while ago it decided that on a lot of channels (most of my favourites) that "No Satelite Signal is being received".
I done a full reset, it has updated to the new Guide thing and channels that are available are fine.
The EPG, favourites and planner all work fine.
I rang sky and they want to charge £65 for sending an engineer out to "fix" the problem, checking the system setup reveals no problem (signal strength / lock all ok).
What are my options? A friend said it could be the LNB, but I don't know which one i should replace it with if I do. Should I get a new box off the bay?
The box I have now is a Grundig (that's all I can see on it).
Suggestions please.
Thanks
Suggestions please.
Thanks
