I've been a little bit concerned over my V8 since i've had it. Ive been looking at it through the side panel on my case and i swear that its leaning down slighty by about 1-2 degrees and slighty tiled right. I dont know what is causing this because the installation was very easy and its very tight. By which i took off the side panel and actually tried moving the v8 ever so gently and it was rock solid, it wasnt budging.
Here are 4 pictures of it. (the pictures dont actually show it as much as you would see it in real life but they were the best i could get).
http://img9.imageshack.us/i/img0101xb.jpg/
http://img218.imageshack.us/i/img0102xj.jpg/
http://img521.imageshack.us/i/img0105bt.jpg/
http://img148.imageshack.us/i/img0106dt.jpg/
Just want to make sure my v8 will be secure and if it is bent by a tiny 1-2 degrees tops, will it be safe? will it ripple the board? (even though there are 3 top mobo screws on too holding the mobo down, obviously
) or might it just be the heat pipes on the v8 bending but the block perfectly flat? im overclocked at 3.5Ghz on my 1055T and i never break 45C w/ arctic silver 5 so it seems to be working. It's starting to scare me a bit thats all and i dont want to end up with it seriously damaging the mobo by bending if it is..
