I am figuring to use the 120 at the back of the case simply for a neater route for the tubing, but am not 100% sure what is going to be the best route to use.You only really need a 480 rad for good temps it will be overkill. I would forget about the 120 at least.
Ill be building my rig again in the next few days and Ive got gtx 480 sli and a 2600k i will post some screen shots of my temps. Ive got 360 and 120 rad.
I would suggest maybe getting the 18w MCP355.
Why not just buy a d5 no messing with them. Ive had the duel mcp355 i didn't think they were that good.
, I have spent way more this year on my PC than most years ever, and I want a new new PSU, and new GTX480 with a EK block, a new D5 would be a step too far budget wiseWhy not just buy a d5 no messing with them. Ive had the duel mcp355 i didn't think they were that good.
Sell the two smaller rads and the pump and buy a D5. Complete rad overkill that will make no difference to your temps as you have them in a single loop configuration.
having more rads
will not lower temps?
Agree will the rest.
If your going to buy another pump why not sell the one you have and put the money to and you have enough for a d5
MCP355s have stronger head pressure than D5s, and that is what matters most in high restiction loops.
