Yeah but I assume most new games will support it..
I think its so unfair ATI doesn't have Physx as theres a slight advantage
ATi declined nvidias offer for them to use PhysX so it's ultimately their fault they don't have physx
I dont think nvidia was exactly giving it away to ati and im sure they would have made sure it didnt run as well on ati hardware as it did on nvidia hardware anyway so it would have been a lose-lose situation for ati.![]()
Is Physx a big factor in today's gaming and would that make you choose NVIDIA over ATI? and is there a way to get the best of both worlds?
AFAIK the deal was if they take up CUDA then they can have PhysX
Mafia II looks pretty good
also games which can run GPU physics (even if it isn't PhysX) run a lot better on nvidia cards than ati cards in my experience
What games are you on about that run GPU physics which is not PhysX that run better on nvidia cards ?
Because unless you have links i think your mistaken as there are no GPU physics games that are not PhysX at the moment.
I know Crysis can do it, don't remember any others though
