- 25 May 2011
I mean will the cores really work that extreme? With gaming
Prime95 does not prove stability, all it does is boil the CPU, you can run Prime95 for hours and then BSOD as soon as you load a game up.
Asus Real Bench is much better.
what a load of BS
I use overnight runs of Real Bench and x264 stress test v2 (not at the same time), as well as gaming to gauge stability. The result is a rock solid OC for gaming, video editing, encoding etc., all the things regular people use PC's for.
I'm not a fan of the highly synthetic stress tests. Not only do they stress in a way you'll never manage in day-to-day use, they heat the CPU an unreasonable amount which can destabilize your OC anyway. I think stability is rather subjective and should represent how you use your PC. If your PC crashes while calculating prime numbers, then it's obviously not stable when doing that. However, how often do you leave your PC calculating primes?
Trouble is, if it is not stable calculating prime numbers, then it is not stable.
So you could be gaming or whatever, then all of a sudden, random crash. You might only see that once a month or something, but it is still not what I would call stable for 24/7 use.
You might think that because it runs cinebench a couple of runs, or 4hrs of realbench your pc is stable. Well it probably is not!! You will find that there is very slight instablity that can rear its head up like once a month or even a year.
Just my 2c.
That's not the case though. Unless you're replicating the same way it crashes in stress testing, you won't see the crash. I've had my 6700k clocked to 4.8GHz for 9 months now, tested with the above methods, never had an issue. As far as I'm concerned, that's 100% stability.
So in your opinion that crash that occurs once a year can only be due to OC and nothing to do with windows or a program ? Once a month the same crash yeah could definitely be a stability problem, needs to be looked at, and can't be concidered stable, but one crash a year could be anything.
Why is it a load of bs ? testing with prime only proves stability in prime , you can test with prime for 24 hours then as soon as you decide to load up a game it crashes or five minutes in and it crashes. Maybe humbug should have said prime does not prove real world stability.
