- 15 Jun 2006
- Amsterdam
what does this crystaliser do ...is it like reverb or something like that?
james.miller said:im sure it does sound better. well, i know it does lol. However, of course, nothing beats straight stereo to an amp and 2 speakers. No effecct any sound card can produce for music does anythign other than degrade sound qualitybut its all about what you want and where you draw that line
Not really. I'd go EMU or M-Audio if I was solely listening to music, but it is hard to beat the versality of an X-Fi: IMO, for videos and games, the X-Fi would get the edge, as those audio "tweaks" while not ideal from a purist point of view work pretty well there (it's not like TV/movies are typically recorded in ultra high bitrate on the sound side of things). And for stereo music, there is always the option to connect an decent external DAC to it, which in most likelyhood would be better than the EMU/M-Audio card. Of course, that's an upgrade path that adds to the cost, but it is there as an option.Lost-Prophet said:I watch TV and a few movies on my pc. So do you think a M-Audio card will be better? Can you recommend one?
Curio said:True, but MP3's aren't exactly "hi-fi" anyway. The Crystalizer just helps give them a lift. I don't see the point in trying to capture a pure hi-fi experience from an MP3 coming through a sound card in the first place - I'd spend the money on a proper hi-fi system instead![]()
Noopz said:I just upgraded from my Nforce onboard audio to M-Audio 2496. Coupled with a decent interconnect, the sound quality is about as good as you are going to get for a 2.1 computer speaker setup.
james.miller said:mp3's can be as hi-fi as you need them to be. of course you cant beat a lossless compressed format, but many many people fail mp3 blind listen tests, so the difference isnt as large as people like to think.
Curio said:What I mean is that I don't get too fussy about sound quality from my PC. If I want proper hi-fi I'll go listen to my Marantz separates. To me, MP3's coming off a PC are a compromise, so anything I can do to make it sound better (to my ears, of course) is fine with me. If the Crystalizer or EQ sound good or rubbish then that's up to the individual, but I don't see the point in getting all "precious" over something that is, by its very nature, flawed anyway![]()
sinister_stu said:The mp3 standard says that audio encoded at 96kb/s will sound the same as the original to a group of trained listeners (I can't remember the exact term, but suffice to say that they are people with better ears than you or I). To my knowledge this hasn't quite been achieved yet but anything encoded at 192 kb/s (using a reasonable encoder) will certainly contain only inaudible differences. So although it is flawed in that it contains less information than the original, it will be inaudibly flawed.
Curio said:OK.....and how about if you play an MP3 using a sound card in a PC, then compare it to the original played on a high quality hi-fi system. Still think you won't be able to tell the difference?
james.miller said:nothing is going to beat a cd player and amp, i never said otherwise. its just some people seem to think there is a massive difference between cd/amp and pc/amp.
