- 19 Dec 2003
- UK
Hey folks,
I wanted to get a TRUE 120MM HSF but it's sold out everywhere
So I have decided to stick with my Zalman 9700LED for now, but it has a 3 pin connector, and my ASUS Rampage Formula has a 4 pin connector.
I want to use the CPU fan at a controlled speed, not having the 4th pin doesn't let that happen and it goes at 2600RPM+ very noisy!
Only solution so far, is to plug the CPU fan into chassis fan header, and control it to 50% speed from there, but to be honest, 50% is still too much!
I don't want the clutter of a fan controller, or fan-mate I just wondered if there is a simple cable I can get that converts a 3 pin cable into a 4 pin cable for a header (not a molex).
Thanks
Thanks
