is there a big difference between cas 4 and cas 5?
11 Apr 2004
Is there much of a real world difference between speeds CAS 4-4-4-12 and CAS 5-5-5-15? And does the performace difference justify the difference in price?
I think it depends on the CPU you are using. The AMD platform will benefit more from lower latencies than Intel. That said, I've never noticed any major performance boost when it comes to lowering the timings in either symphethic or real time benchmarking. Not worth the extra cash IMO.
If you had two computers setup, exactly same specs but on one computer the Memory was running at 800MHZ with timings of 4-4-4-12 and then on the other computer the memory running at 800MHZ 5-5-5-15. You had to pick the system that had the tighter timings on, it would be a guess more than actually knowing that this system had the tighter timings.
So in other words no you wouldn't really notice the difference to be honest.
£20 can be a significant percentage when looking at value RAM.
I've been benching superpi a bit today and haven't found a great deal of difference between 3-3-3-9 and 4-4-4-12 on my C2D rig, so I'd imagine it's a similar story for cas4->5. Seems like FSB is probably more important although I need to do some more research.
you need a better benchmark
something that accesses the memory often and runs for a long time
helmutcheese said:
And the slacker the timings the worst, It will be bigger gap from 5 to 4 then from 3 to 4.
So where does that leave DDR3 with timings of 7-7-7-21 and 9-9-9-27 and nearly 3 times the cost?
well what's the difference between them? all I can see is the same speed as higher end ddr2 but with a higher latency.
ddr3 is an evolution of the sd-ram standard. ddrI introduced 2 instructions per cycle (hence Double.Data.Rate). ddrII increased the prefetch buffer to 4bit (up from 2bit with ddrI). ddr3 increased that again to 8bit. that's the main advantages over ddrII, anyway. increasing the prefetch buffer and over little improvements does have an effect on latency though.
the main promises of ddr3 are around a 16% lower power consumption and much faster achievable speeds. as with ddrII (and ddrI), ddr3 has been introduced at a point where its slacker timings and its operating speed (although fastest) dont offer any real advantages over the current crop of ddrII modules.
watch this space though. because ddr3 will get very quick.
helmutcheese said:
Excuse me, we are compairing apples to apples not apples to oranges, we are talking DDR2, not DDR2 v DDR3.
perhaps he'd like to know the difference and concidering its his thread, perhaps you should help him or stay out?
Well, I guess it depends what your goal is. If pure memory performance is all one cares about then maybe you wanna use a memory-specific benchmark, but for general unthreaded system performance I don't think there's much wrong with superpi 32M.
On my travels I came across this: http://www.xbitlabs.com/articles/memory/display/ddr2-oc1ghz_8.html
...which pretty much backs up what I was saying about the importance of FSB relative to timings. As you can see, DDR2-667 at 4-4-4-12 gets beaten comprehensively by DDR2-800 at 5-5-5-15. Heck even at 3-3-2-8 it can't live with it.
James.miller why are you a total ***** and I thought you had me on ignore. :rolleyes:
I did not realise he was wanting info, I though he was pointing out a fact so you need to learn to stop getting on my case or I will report you to staff as your a total lamer, this is the 3rd thread you are doing so in.
