thanks, it looks pretty easy but i've never soldered beforeArmadillo said:Bridge two pins inside the ps2 , cheapest way to do it. Just search ps2 rgb fix online , should find the relevent diagrams. Not sure if it can be done on the newer ps2's though.
Marcos said:Oh you havent heard? If you try to play a DVD through an RGB cable on the PS2 it shows up green
I want to play DVDs through the PS2 with RGB without the Green screen
droolinggimp said:I used a RGB cable on my PS2 and it was fine.
No idea what you are on about![]()
Dark_Angel said:Without wishing to be a pain, its worth remembering that there is no talk of console mods allowed on this forum, so I would highly recommend taking down the link to the picture.
Marcos said:Either you have a PS2 version i havent heard of before that allows it...
ALL other PS2s ever produced have a restriction on DVD playback through an RGB cable, the restrictions forces the output to show the picture in Green.
You probably have a switchable RGB cable or something, thats what i use right now, i switch from RGB for games to composite for DVDs. I hope thats not the case, cause that would mean you've bought an RGB cable but have been running it in composite mode all this time![]()
droolinggimp said:the cable that I used was an official RGB cable and it worked pefect on all my TV`s..The picture quality was obviously loads better than the crappy composite you get as standard..
Sorry if no one belives me but thats the way it is..
Marcos said:Ok lets just confirm a few things.
1. You have fat/older PS2
2. You bought it new and it is unmodified/unopened
3. You play DVDs through the RGB cable and there is no green screen effect
If so, you must have a rare PS2 version that i dont know about that has no restrictions, or your console has been modified and you might not know about.
I can't see any other reason for it
[SKR]Phoenix said:You could be wrong? oh, the shame!
Don't have a fit, it does happen.
dirtydog said:I use the Blaze advanced RGB scart cable with my PS2 and it plays DVDs back fine, no green screen.
Nismo said:But thats because it has a switch on the lead to change it doesn't it? Effectively means you aren't using RGB anymore.
That was the case when I had the blaze lead and a PS2 anyway, things might have changed since and it might auto-switch.
Marcos said:really? thats new, and annoying
