Is there any decent metal case flash drives with metal eye
13 Jul 2005
Devon
I'm forever forgetting where I have put my flash drive so next step is to buy a solid 64gb and attach it to the keys or even on my id lanyard. Everything seems to be plastic.
Just google "all metal usb flash drive".
Can't post links, but you will find what you looking for.
Example:
Samsung BAR Plus 64 GB Type-A 200 MB/s USB 3.1 Flash Drive Titan Grey​
I recently got one of these Integral 64GB 360-Dual USB 3.0 Type C & Type A Flash Drive with Solid Metal Casing.
Thanks when I did a quick search the results coming back were just cheap ones saying not so good things. I will do a proper search.
Kingston Datatraveler-micro is probably ideal - smaller form factor so probably less likely to get damaged than full size drive as well
