- 5 Nov 2004
Tappits said:yes just get a better set-up. will cost less in the long run.
Erm, No it would cost more. Just because his brakes are not working to 100% of their ability doesn't mean the answer is to upgrade. I'm sure if he changed the fluid and possibly the disks if they are worn below the minimum thickness, the brakes would have a great improvement for around £40 worth of parts.
