Is there anything drastically better than a TRU?
Im actually looking at the silver arrow now, thought about watercooling. But the cost is prohibitive, now that im running low profile ram it seems like a pretty cheap option.
I doubt you'll see much, if any, difference switching from one decent air cooler to another. The only real way forwards is custom water, yeh it's pricey, but it could well slash 10-20 degs of your temps as opposed to the 5 (if you're lucky) of switching air coolers.
Are you running watercooling yourself mate? It does sound intriguing, and ive specced up components for doing it. New it would cost about £250.00 for me, (ive got some high quality fittings and tubing already), bitspower barbs x10 and 4m of masterkleer 7/16" tubing. Id just need a pump, res, cpu block and rad. Cooling gpu's is definitely out of the question though. Id probably have to get the case modded as well, as id prefer to have the rad mounted internally. 360 rad in the roof of the case. Lian Li A70F which has the space.
Lol, who are you trying to convince? ;)
you know deep down you want that loop. :D
just go for it and keep an eye out in the MM
My 2500k seems a little toasty when clocked at 4.5ghz at the required 1.33v and was wondering if there was an air cooler markedly better than my trusty old TRU (non extreme). Would something like the silver arrow or noctua be a big improvement? In the meantime i've dropped the vcore to 1.28v and the clockspeed down to 4.3ghz.
I didnt see anyone ask this but what temps are you getting which you class as toasty?
Yes I am, switching from an Antec H2o 920 with 2 Vipers in push/pull to the custom loop took about 15 degs off my 2500K load temps at 4.7Ghz. It is well worth the money I think, but I guess it really depends on whether or not you have the spare cash. If you can't fork out for it all at once I suggest saving up and buying one piece (or a few pieces) at a time, that way you don't skimp on components.
