Is there away to stop
19 Mar 2011
The majority of the time when i shut my pc down i get messages "this program is preventing windows from shutting down" is there away to prevent this other than not turning the pc on :)
Depends which specific programs are preventing windows from shutting down?
Often it's the icons that live in the system tray, and they can often be disabled or completely removed.
Sometimes it helps if you close the program yourself manually before you turn off the PC.
If it keeps happening it is more likely a problem with the program than your PC.
Does it shut down after a short period of showing that message or get stuck until you click shut down anyway?
You could change a (registry iirc) setting to force the termination of programs on shutdown but TBH it's not something I'd do as you can lose data in those programs.
Best thing to do is either close steam before shutting down or just leaving it to shutdown on its own so steam finishes syncing saves/settings or whatever.
