Is there much difference between these two SSDs
It's up to you if you want to stretch the extra £20+ they cost but they're not delivering £20 worth of extra performance compared to say the Force 3.
I know that but I never really saw their own products as the best you could get for the money considering their price!
Adata isn't exactly the brand you want to entrust your entire OS to.
And there seems to be a lot of OCZ related failures as of late, not just SSDs but other compoents too.
Corsair Force 3 120GB is the one to go for:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-021-CS&groupid=1657&catid=2101&subcat=2103
OcUK stock ships with 1.3.2 firmware so just update to 1.3.3 via the Windows utility and it will be running flawless.
i thought agility3 and force3 have the same controller which is the culprit behind all those issues
My Force 3 has been running 2 weeks no problems, firmware updated on day 1. A mate of mine has had his 1 month longer than me and his is also perfectly fine.
Both bought from OcUK.
btw my vertex 2 died 2 weeks after applying the firmware update that was supposed to address these issues..
individual cases dont really say a lot for failure rates as a whole :)
I already have my OS on a 64 gb C300, and only considered a 120 gb for games with the adata's pre order price.
Since its cheaper, I think I will preorder the adata.
