Phyre said:Just found some old stuff (few years). Should it be OK? It's Arctic Alumina.
Socaddict said:doesn't the freezer 7 pro have paste already applied to the bottom? which shoudl be pretty good, IIRC.
serenity888 said:so if you were to add some other thermal paste, would you need to remove whats already on the heatsink?
easyrider said:I use Isopropyl alcohol
Gets it clean as clean as be![]()
Tute said:The Akasa TIM-Clean stuff sold from this very site does a wonderful job too!
easyrider said:Or nail varnish removal pads![]()
.I like it. I've been using Jay coths which usually leave fibers aboutw3bbo said:with some coffee filters
w3bbo said:Couldn't be sure but as its got a lemon 'scent' then I would have thought it also has some sort of oil in it which is not good if you want to perfectly clean a cpu/HS.
...which probably leave some threads on your clean cpu?HS - bad. I worry that you have some nail varnish removal pads in the first place and don't try telling me they are the missus'.
Isopropyl Alc with some coffee filters/lint free cloth is best imo.
w3bbo said:@ Easy - I'm tempted but I don't think I could face asking the counter girl for them...its bad enough buying panty liners/tampons etc (for the missus!) lol. Coffee filters however don't seem to raise any eyebrows![]()
