Is Thermal Paste Required?
easyrider said:
If you are secure about your sexuality then it shouldn't really be a problem. ;) :p
LOL, plus I think most people know that Nail Varnish remover can be used for many things, not just removing nail varnish! :D
How the hell did this turn into questioning my confidence in my sexuality lol. So a checkout girl knows to use nail varnish remover for cleaning cpu's?
It was a joke btw, I wouldn't expect a shop assistant to believe I was using panty liners, nor you using nail varnish remover for what it was designed for ;)
...I'll get my coat :D
:D
Socaddict said:
doesn't the freezer 7 pro have paste already applied to the bottom? which shoudl be pretty good, IIRC.
It comes with Arctic MX-1 pre-applied which is pretty good stuff and gets good reviews. However I have found that this sets quite hard after a period of use making it difficult to swap your processor/HSF. So now I always remove it and apply AS5 instead.
i use my finger, tbh 1- 2c doesnt make that much difference. Although it has to be said i think im losing the OC bug. :eek:
