is this ok for a coolermaster stacker?
Yep... won't make it any quieter though if that's what you're hoping.
whys that ? ever since i fitted H20 kit and get a like a draining humming and when one side of case is off it stops so i want to drain out the psu or my top fan which must be the cause of it
The humming is probably the pump vibrating slightly and going through the case, try separating the pump from the rest of the case with it sitting on something soft, a folded up piece of kitchen paper or toilet paper works fine for this.
If it turns out that it is the pump you can then do something more permanent looking.
Wouldn't bother with the Paxmate.
thanks pink floyd i will try this.
if nothings vibrating then isolating the pump with something soft will do nothing, it might be your psu humming
thats what i suspected will have to get a new one just need to find a decent one now will order one later on after a nice quiet 800 - 1000 watt for future proof
