is this possible...? BT Phone cabling over Ethernet..>?
11 Jun 2004
Middlesex, London
Hi all, Need some help / advise please.
....is it possible to connect up a BT Phone through a Network port..?
i.e. - My friend has a Network port near his Sky box - but not a BT Phone Socket.
So we'd like to connect the Phone line for the Sky box into the Network port.... and then wire the other end of the Network into a BT Phone socket...
Thanks
No reason why not. Not sure if there are any read-made adaptors out there, or if you'll have to build your own, but given it's just wires, you just need to make sure you get it right both ends.
YEs you can, I've done/doing it also while using the network side.
Cut off the ends and split the 4 pairs into 2, one for phone and one for internet (if you want to use it). You can buy the plastic phone ends from wilkensons for £1 which you place 4 wires into and clamp the metal teeth down which seals it and the other end wire (sky end) into a 60p phone junction box.
If you wanted the ethernet to work also the ends are ~50p and you can buy a tool (or bodge it) for £5. it will run @ 100mbps but you have to have the wires in certain (can look later if you wanted) pins as all 8 wont be there.
ok - This sounds good - But I'd rather not do a cut and shut job... Surely there is adapter / plugs / dongles available to do this... I just don't know which one's I need - lol
"RJ45 to Telephone, PABX Master, telephone office exchange"
on one end?
"RJ45 socket to UK Telephone plug adapter"
on the other; with a short patch cable?
