is this possible . . .
17 Jun 2006
To build a PC with all the gubbins in the case EXCEPT for the HDD's which are maybe mounted outside of the case for ease of access!
Pro's/Con's please and what types of SATA cable options would there be?
Khushy
It is entirely possible depending on how you want to mount them, it isn't as if there is a forcefield outside the case that will stop them. :)
It'll probably look messy and put you at greater risk of knocking them but if you need the ease of access it is perfectly do-able. 1m SATA cables give you a fair bit of reach in the positioning. The other option is to use eSATA drives as they are already intended to be used outwith a case and are as fast as the internal ones.
esata is the way forward
no speed penalty and is exactly the same speed as normal sata
just need an esata enclosure and an esata bracket on the back of your motherboard. Some esata enclosures include a DIY kit and turn one of your PCI blanking plates into one.
If you're looking to build a new machine with eSata I know the Abit IP 35 Pro has two esata ports on the back next to the USB ports. Makes things a bit easier if you want to do it.
You can actually buy a PCI bracket which has the SATA data AND power connector on it, so dont even need a caddie.
http://www.**********/images/products/434445-A.jpg
You can get a lot of different backplates for pcs. I have a 3 x molex one. Handy for attatching cathodes (one behind my monitor) and testing fans etc. Just search for A.C.Ryan, they do them.
