Is this PSU adequate for my build?
24 Feb 2003
Porthcawl and Southampton
Done a bit of searching and reading and my gut feeling is that it'll be fine but I wouldn't mind some input.
I already have a Corsair 450W psu that I would like to use.
The build is:
E5200
4Gb Kingston Value RAM
Gigabyte GA-P35-S3G Motherboard
Gigabyte X1950 Pro Graphics
Will only be one optical drive and one HDD.
Will this PSU allow me to overclock at all with new RAM?
Any problems running a couple of case fans?
Thanks...
Should be plenty - the x1950 requires a 450w PSU. Nothing else is particularly power hungry, so like philtorrens said, should be enough overhead for overclocking.
Any reason why you're sticking with the 1950?
