Is this the best wireless antenna booster
Not used a booster before but the gain is pretty amazing and the range should be good on that.
It will be a lot more directional than the usual kind of antenna so dont expect it to fill your house with signal it will just send a lot more of it in a certain direction (which may bewhat you need)
Was hoping to be able to point it at uni library which is about 300m away (across a meadow though)
you need a very directional preferably outdoor mounted antenna probably a yagi type ie looks like a tv aerial, main problem is getting the right connecter
+15db may be enough, more would be better
