Should be more, unless it's being accessed by something else as well, or you're copying small files, or the source drive is slow, or the source drive is being accessed by something else as well. Once you've ruled out all of those, and probably some more I forgot about, you can decide whether it's slow or not.
There are all sorts of factors that can affect this such as fragmentation and the speeds may also be misreported. Test the read speed, if that's normal then the write speed will be too.
