- 25 Nov 2009
my phenom II x2 550 is currently running at 3.825 GHz with 1.5 volts on air and temps peak on full load at 34 degrees, how much colder would water get it???
Yes, watercooling is worth it.
Asking how much cooler it would be is a stupid question. Watercooling will run at at a fraction of a degree above ambient if you use enough radiators, or well under room temperature if you put the radiator somewhere cunning.
sounds like either you're reading the socket temp or your not getting accurate temp readings
with that many volts going through your cpu you'll have a much higher load temp tbh...
[/URL][/IMG]![]()
i see what your sayin im just wondering how much closer to room temp im likely to get with a simple wc loop. i suppose there are too many variables tho for you to answer accurately.
Like in a fridge or outside on a nice winters day!
Does it help if I tell you my amd 7750BE was loading at one degree higher than it was idling when it was watercooled?
JonJ678
That is one mad idea, a water butt!
Would love to see you go to a LAN party with that! Mind you, could pop ya beers in it to cool![]()
is it possible to get below room temp on air with a really high airflow over the heatsink?
you could... if you had a big pipe coming from a cave buried deep in the ground, connected to your push fan on the cpu cooler![]()
