- 6 Sep 2016
My speakers are 50kg each so I doubt drivers overcome the mass of the speakers themselves, spikes into hard floor so zero movement. Guess different have £80 floorstander cheap n nasty
Have come close to getting a UMIK-1 before. Have a tripod but I'm not gonna do this as my thoughts on the feet have been made clearTBH a miniDSP UMIK-1 and REW should answer if the improvement is real or a placebo, around £100 if you fancy giving it a go, you will need a tripod though.
The problem i have with a lot of this audio stuff, is its very hard to convince yourself, something you've just bought doesn't improve things. I'm in the snake oil camp, where you get people recommending horrendously overpriced cable, and a new one on me (some guy from my work sent me a link for a laugh), an oil that you can put on you cables to improve them. Imo its also quite hard to 'remember' exactly what you heard pre upgrade, so your brain could be playing tricks on you.
You were still buying within the family sound of KEF, so not really in the same boat as 3t3P would be with that front stereo pair.Don't think it matters not matching side/surrounds I've had one brand for front three, side and rears from two different brands.
Now have front three and rears same brand same range but sides are another brand, and bipole, as the matching side brand are dipole, which I have but again another brand but I think dipoles not the ideal side speaker with more modern discrete soundtracks.
I'd rather have non matching but better speakers than matching but lower quality. For example I had kef q75 years ago, the matching q95c was a piece of trash, awful. Two drivers. So bought non matching kef model 200 reference and far higher quality sound, and frequency response (4 driver)
so whose cable do you recommend .. I'd bough onyx 2025 @£1.30A few years ago I stumbled across a coax cable for digital signalling that I felt would offer some genuine advantages for subwoofer use.
the material has free plasticiser present. This can migrate into wood and wood-based surface preparations, leading to surface staining marks. If this is important to you, take note. The staining issue is not large but it does exist. It is dependant upon the surface treatment of the host material.
so (new word i learned) that seems to be reussen shielding -The cable I use and sell is made by Belden, and it doesn't use a spiral wrap. It's a woven braid,
I have looked predominately at the resistance and the capacitance +cost, on cables I selected, with the idea on minimising loading for the driver .. but will think more about shielding ... had looked at some ebay 2nd hand van damme plasma last time I needed some.
