- 15 May 2012
- Louth, lincs
Got my pump/top/res combo mounted to the MB tray, already using the aqua computer mounting kit(yellow sponge bits with bolts either side) but i'm getting a hum/drumming noise is there anyway i can mount it better? Moving it is not really an option.
The combo is quite heavy so the bolts being used are pretty tight which i suppose defeats the object of the sponge dampers
The combo in question, the res is 80x120mm
